dynatrace can put https response body
Web App is React.js sending data as HTTP Request Method: PATCH, customer needs HTTP response data displayed in Dynatrace.
ChadTurner
DynaMight Legend
DynaMight Legend
were you able to get a resolution to this?
-Chad
trevor_masseng1
Dynatrace Mentor
Dynatrace Mentor
If this page and the backend service that is being hit are both monitored by Dynatrace, you should be able to dig into the User Action, view Top Requests at the bottom of the page, select the request/service, and look at the purepaths or some other breakdown to see more data, depending on what you are looking for.
