Backup Dynatrace Managed cluster manually
jaramos
Participant
Is there a way to create a manual backup of my Managed cluster?
Thanks and regards.
Jose A
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
No, by any means I think. But what do you mean manual? Using 3rd party software or triggering that manually instead automatically? What's anyway the use case?
Senior Product Manager,
Dynatrace Managed expert
