Capture TLS/SSL related errors in Dynatrace
nikos_leventis
Visitor
Is it possible to capture TLS/SSL related errors in Dynatrace?
For example, a bad configuration in one of the IIS servers triggered "TLS handshake failure".
Another example is when a certificate is expired and users receive "NET::ERR_CERT_DATE_INVALID"
Can we capture those errors within Dynatrace?
Kind regards.
AntonioSousa
Regarding certificate expiration, there are good extensions for monitoring certificate expiration:
SSL certificate validation.
Antonio Sousa
