Charts that shows consumption-trend of DDU, among others
waikeat_chan
DynaMight Pro
DynaMight Pro
If I am not mistaken, there used to be charts that shows consumption-trend of HU and DEM-Unit in the 'accounts' page of DT SaaS.
This feature is not available anymore?
I want to see the consumption-trend of DDU in a DT SaaS
SantiPalacios
Dynatrace Advisor
Dynatrace Advisor
Currently the best place that you can find this is by going into your admin UI through account settings >> licensing details and at the top right corner, you should have a link called "view consumption". This will give you the consumption trend for all your licensing consumption details.
Hope this helps
AntonioSousa
Specifically for DDUs, you can access it through Settings, as shown below. It is also available in Custom Charts.
Antonio Sousa
