Best way to implement Prometheus Metrics to Dynatrace
Sylvie_Perriere
Visitor
Hello
I have a lot of custom metrics already existing for my project via spring boot application and many endpoints.
How can I reuse it to be used in Dynatrace with the better way?
I have began to use Micrometer in a springboot application, but it seems that I need to re-implement all metrics to use Dynatrace libraries.
Any idea ?
Best regards
JamesKitson
Dynatrace Guru
Dynatrace Guru
If this is in Kubernetes you can set up the Kubernetes integration and there is a new feature to have it scrape your metrics endpoints if you annotate them with the required entries. This brings those metrics into Dynatrace.
https://www.dynatrace.com/support/help/technology-support/cloud-platforms/kubernetes/monitoring/moni...
Alternatively you could use the generic metric ingest in a script or something like that to report the metrics back via the OneAgent: https://www.dynatrace.com/support/help/how-to-use-dynatrace/metrics/metric-ingestion/ingestion-metho...
sonja
Inactive
Hello! I just wanted to let you know - and for future references - that we have published a new version of the micrometer registry for Dynatrace: https://micrometer.io/docs/registry/dynatrace, with simplified deployment and that automatically connecting your Micrometer metrics to the topology.
Documentation: https://www.dynatrace.com/support/help/how-to-use-dynatrace/metrics/metric-ingestion/ingestion-metho...
Sonja
