No names in metric scripting integration
henk_stobbe
DynaMight Champion
DynaMight Champion
See below, I'm missing the Metric name (only the key is available), is there an option to fix this?
KR Henk
JamesKitson
Dynatrace Guru
Dynatrace Guru
All the new metric ingest mechanisms are like this right now (e.g. Prometheus scraper, StatsD exporter, etc...). There's nothing I'm aware we can do right now but I have been told there is something planned to handle this.
robert_schausbe
Inactive
We will allow to set a custom metric display name (primarily for custom metrics) in the future for all metrics ingested via new metrics ingest endpoint (https://www.dynatrace.com/support/help/dynatrace-api/environment-api/metric-v2/post-ingest-metrics/)
Also, with version 208+ the metric browser will also show the metric-key in the name column, in case the information is not set
