ActiveGate plugins: how to use "dropdown" config UI input
r_weber
DynaMight Champion
DynaMight Champion
The ActiveGate plugin JSON reference mentions input type "dropdown", however it is missing the documentation how one would prepopulate the dropdown field:
It would be nice if the documentation would also mention how to use the drowpdown and prefill it with options?
Anyone has done this and an example for it?
6 REPLIES 6
Mike_L
Dynatrace Guru
Dynatrace Guru
The property needs to look like this:
    { "key" : "instanceYellowAlert",
      "type" : "Dropdown",
      "defaultValue":"No",
      "dropdownValues":["Yes","No"]
Mike
Mike
r_weber
DynaMight Champion
DynaMight Champion
Thanks Michael, great to have you instead of complete documentation 🙂
Experience beats everything 🙂
Mike
r_weber
DynaMight Champion
DynaMight Champion
Well, I'd say just need to know where to ask. Guessing properties by trial and error isn't fun.
That's very true.
I will send the documentation feedback to the responsible team.
Mike
Mike_L
Dynatrace Guru
Dynatrace Guru
The documentation here shows what the names of the fields are: https://www.dynatrace.com/support/help/extend-dynatrace/extensions/development/extension-how-tos/ext...
Mike
