• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Dynatrace /
  • Dynatrace Open Q&A /
avatar image
Question by dynatrace A. · Jan 12 at 04:39 AM · configuration Dynatrace Managed installation cmc
How to change Port Dynatrace Managed (Web UI 443)
Can I change the default port Dynatrace Managed (Web UI 443) to another port?
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Best Answer
Answer by Radoslaw S. · Jan 12 at 07:18 AM
Theoretically, it is possible by modifying a rule in iptables that redirects traffic from 443 to 8022 (NGINX). However, such a modification is not supported as many places in communication will refer to :443 port hardcoded.
What you may want to do instead, is to set up a load balancer exposed on a custom port and keep Dynatrace Managed hidden behind.
Comment
Babar Q.
Patrick H.
2 Show 5 · Share
avatar image Babar Q. · Jan 12 at 08:58 AM 0
Share
Hello @Radoslaw S.
We have the suggested setup referred to in your comments, but the only difference that we are using port 443 (because the cluster node is listening on port 443).
I just wanted to know where/how to use the custom port.
https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-managed/configuration/which-network-ports-does-dynatrace-server-use/
Babar
avatar image Radoslaw S. ♦♦ Babar Q. · Jan 12 at 09:11 AM 0
Share
Hi Babar,
as you see:
443 is Routed to local port 8022 using an iptables' prerouting rule. This port must remain open. All Dynatrace communication to the cluster is handled over secure socket HTTPS communication (port 443) with strong cryptography to guarantee your data privacy.
So Dynatrace Managed nodes does not actually listen on 443. You could either have your LB redirect to :443 port or :8022 (NGINX) - in these cases you don't need to care about cookies/session-stickiness as NGINX handle that. Or you can redirect to :8021 (server) - in that case you need to care of session-stickiness.
There's also an option you disable firewall service (clear iptable rules) and manage it by your own to set it up.
avatar image Babar Q. Radoslaw S. ♦♦ · Jan 12 at 09:29 AM 0
Share
Hello @Radoslaw S.
Now I understood the idea that there is an already prerouting configured rule from 443 to 8022, so for the LB SSL certificate, we can use the 8022 instead of the 443.
Is my understanding correct?
Babar
avatar image Radoslaw S. ♦♦ Babar Q. · Jan 12 at 09:32 AM 0
Share
yes, you should be able to
avatar image Babar Q. Radoslaw S. ♦♦ · Jan 12 at 09:39 AM 0
Share
Hello @Radoslaw S.
Thank you for the endorsement.
@dynatrace A.
Now you can implement the same solution to achieve your objectives.
Babar
avatar image
Answer by Babar Q. · Jan 12 at 05:58 AM
Hello @dynatrace A.
I guess it can be possible only if we use our own trusted SSL certificate, but someone else in the community can correct this understanding.
https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-managed/installation/install-your-own-ssl-certificate/
Babar
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
33 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Parameter the OneAgent installation.
Instead of using DT Managed Config that we've backup, is it possible to use the Server-Image of Managed Node to perform restore?
Would I be able to pass parameter/option to OneAgent installer if using Windows Group Policy?
Problem activegate installation
Managed Silent Install - Diff between datastore-dir, cas-datastore-dir and svr-datastore-dir
Forum Tags
mobile monitoring dotnet iis chat kubernetes servicenow amazon web services feedback mysql mainframe application rules rest api cassandra dashboard oneagent sdk cmc waterfall chart application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo opentelemetry integrations activegate auto-detection high five award uem webserver usql iib test automation license ios news migration management zones ibm mq web services notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming resource javascript appmon ai availability tipstricks automation extensions diagnostic tools session replay permissions search davis assistant auto-update faq documentation problem detection http monitors easytravel apdex network docker tags and metadata cloud foundry google cloud platform synthetic monitoring lambda process groups account usability dynatrace saas gui paas openshift key user actions administration production user actions postgresql synthetic locations upgrade oneagent security Dynatrace Managed user management python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting performance monitoring NGINX action naming geolocation linux nam installation error reporting database mission control apache slo mobileapp RUM php azure purepath davis scripting aix nodejs android
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
