• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Dynatrace /
  • Dynatrace Open Q&A /
avatar image
Question by Handerson M. · Jan 13 at 09:03 PM · Dynatrace Managed activegate linux
Questions about cluster Active Gate
I hope your are safe.
I Have some questions about Cluster Active Gate.
We are deployng a Dynatrace managed with 3 nodes.
We already installed the nodes e three Environment Active Gates for two Environments (one for homologation and two for Production)
To install Environment AC and Nodes we use an proxy with communication with mission control.
No Agent installed yet.
So, the customer want monitor a RUM Mobile:
Questions:
1 - Already installed Environment active Gate, can i install Clusters active Gate? The Environment AC will find this Cluster AC? Or do I need unnistall the Envi AC?
2 - We will deploy the Clusters active Gates in DMZ network, but the customer have a load balance, like the scenario 3 of Managed deployment. They will provide the DNS and ssl certificate. Do I need import the ssl certificate from Cluster Active to Load balance? What the address i will put in URL beacon?
Best Regards
Comment
HIMANSHU m.
People who like this
1 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Paco A. · Jan 14 at 11:28 AM
perhaps you have misinterpreted the documentation.
If you are referring to this: https://www.dynatrace.com/support/help/shortlink/public-managed-sgw#before-you-begin, what you can find there is the possibility to reduce the number of AGs needed by installing multi-environment AGs.
Comment
Handerson M.
HIMANSHU m.
2 Show 1 · Share
avatar image Handerson M. · Jan 14 at 12:46 PM 1
Share
Thanks for your support Paco A. I saw this part of the documentation: " if you plan to use the Environment ActiveGate, the deployment order is important: " https://www.dynatrace.com/support/help/shortlink/managed-deployment-scenarios#scenario-2-pure-dynatrace-managed-setup
Best Regards
avatar image
Answer by Radoslaw S. · Jan 14 at 12:21 AM
Hey,
Of course you can install ActiveGates in any order - they will find out about themselves automatically.
just take a look here to see how the traffic will flow and what are the priorities for agents to select the route. For Mobile RUM of course it will go immediately to Cluster AG and then to the cluster.
https://www.dynatrace.com/support/help/shortlink/sgw-availability
You need to configure a public endpoint in CMC (Settings -> Public endpoints) as your Load Balancer address - as you want that Mobile RUM agents use exactly that address. Certificate will be verified of those that you have at Load Balancer. Of course then your Load Balancer will need to trust those that are in Cluster AG. If you use Dynatrace-provided certs, you should be good to go as they are valid CA. If you use your custom self-signed certs, then you might need to import public cert and chain of Cluster AG to your Load Balancer.
So the traffic always go like that:
Mobile RUM -> Load Balancer -> Cluster AG -> Cluster
Cluster AG doesn't know about LB actually (and doesn't need to :) )
Hope this helps!
Comment
Patrick H.
HIMANSHU m.
2 Show 3 · Share
avatar image Handerson M. · Jan 14 at 12:52 PM 1
Share
Thanks for you help @Radoslaw S.
I Understood!
Just more one question. In this case, do i realy need a valid DNS for Cluster AG or can i use a private ip? And if I need an valid DNS, is it better to use the DNS provided by dynatrace?
Best Regards
avatar image Radoslaw S. ♦♦ Handerson M. · Jan 14 at 01:02 PM 2
Share
In case of just (Mobile) RUM and Synthetic - yes, you can have a private IP. Valid DNS has to be provided by you in the Load Balancer - as Dynatrace has no access there.
avatar image Handerson M. Radoslaw S. ♦♦ · Jan 19 at 08:25 PM 1
Share
Thank you very much Radoslaw!! =)
avatar image
Answer by Chad T. · Jan 13 at 09:55 PM
I might not be following your question correctly, but here are the fundamentals:
Dynatrace offers two types of ActiveGate: Environment ActiveGate and Cluster ActiveGate. If you use Dynatrace SaaS, you only need to install an Environment ActiveGate. Dynatrace Managed deployments typically require both ActiveGate types, though the most important type for Managed deployments is the Cluster ActiveGate.
Cluster AG: https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-managed/installation/how-to-install-a-cluster-activegate/
Environment AG: https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-activegate/basic-concepts/when-do-i-need-to-install-an-activegate/
The biggest difference is what data is being passed. The Cluster AG handles things such as Mobile App Connection, UFO Connection and so on. Where the environment AG handles all the metrics coming into Dynatrace from the Oneagents, to Synthetics, to VMware integrations, Log monitoring and so on.
Comment
Handerson M.
HIMANSHU m.
2 Show 1 · Share
avatar image Handerson M. · Jan 13 at 10:15 PM 1
Share
Hi Chad T,
I Will explain better. I saw in documentation that for deploy Cluster AC, it need be installed before to install Env AC. Because Env AC need to knowsi f there someone Cluster AC deployed. So, in my case there 3 Env Ac installed. Can i install Cluster active gate to collect RUM mobile and this cluster AC Will be able to connect with Env AC already deployed?
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
33 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Error while adding the new node to managed cluster
How long would OneAgent keep trying to reach to Dynatrace Managed if Dynatrace Managed is down?
How to specify network interfaces during installation
Active gates for mutliple Vlan
using DataPower as a proxy between SGW and Dynatrace server
Forum Tags
mobile monitoring dotnet iis chat kubernetes servicenow amazon web services feedback mysql mainframe application rules rest api cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo activegate auto-detection high five award uem webserver usql iib test automation license ios news migration management zones ibm mq web services notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai availability tipstricks automation extensions diagnostic tools session replay permissions search davis assistant auto-update faq documentation problem detection http monitors easytravel apdex network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration production user actions postgresql synthetic locations upgrade oneagent security Dynatrace Managed user management python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting performance monitoring NGINX action naming linux nam installation error reporting database mission control apache mobileapp RUM php azure purepath davis scripting aix nodejs android
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
