Does AS400 ActiveGate Extension supports for host of version 7.2?
waikeat_chan
DynaMight Pro
DynaMight Pro
Came across this while reading about ActiveGate extension for AS400:
Just want to double-confirm here:
Instead of version above/newer than 7.2, my prospect has their IBM host running on Exactly 7.2.
So is it supported?
Best Regards,
Wai Keat
diego_morales
Dynatrace Advisor
Dynatrace Advisor
Hi Wai,
Yes, it supports 7.2, 7.3 and 7.4. Older versions are no longer supported even though they may work.
Diego
