18 Jan 2021 09:28 AM
Dear All,
Can we increase the message string length of the reasons for failed requests? The following string is an example where we do not know after the spent w ..........
Root causes for requests that failed with System.Data.SqlClient.SqlException / Connection Timeout Expired. The timeout period elapsed while attempting to consume the pre-login handshake acknowledgement. This could be because the pre-login handshake failed or the server was unable to respond back in time. The duration spent w ..........................
Babar
21 Jan 2021 08:51 AM
Even in OneAgent SDK is there limit. I suppose that this can be because of memory consumption. If really long messages will be taken for exceptions you can produce overhead because of that.
21 Jan 2021 09:00 AM
What could be the optimized solution to this limitation then?
Sometimes customers/vendors ask us to provide the complete string.
Babar
10 Jan 2022 02:47 PM
Hi @skrystosik, I see it's been a while since this topic appeared, but would you have something to add regarding Babar's question above? Let's make this thread a bit more complete! 😄
