Integration with IBM OMEGAMON
Babar_Qayyum
Dear All,
Can we integrate the Dynatrrace with the IBM OMEGAMON?
We want to consume the IBM OMEGAMON generated/monitored data to display on the Dynatrace dashboards.
Babar
5 REPLIES 5
Babar_Qayyum
Hello @Patrick D.
Thank you for sharing the good news.
From where I can get the integration monitor?
From where I can get the integration documentation?
Babar
Hi Babar,
Do you have any details regarding this integration? I am looking for a solution like this.
Derick
Hello @derick_hewetson
We did not continue with this integration due to the OMNIbus.
Babar
STiAT
Advisor
Well, you can using IBM Integration Bus, we've done so in the past. Depending on your setup you can use the OMNIbus HTTP API too if you do use OMNIbus.
That said, it will very likely be your effort to integrate those systems, there is no standard connector between Dynatrace and OMEGAMON to my knowledge.
Hello @STiAT
Thank you for your comments.
We have IIB as well but do not have the OMNIbus.
Babar
