Do we have any possibility to monitor empty log file
mayana_khan_ext
Newcomer
I want to monitor the log file and send an alert(problem) when the application process stops writing events to log file.
does anyone already implemented it?
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
That one is tricky, but there is an upcoming alerting feature in Dynatrace release 212 (rollout in the next 2 weeks) that helps to solve that.
This feature allows you to alert on missing data.
So my proposed way would be:
1.) Define a log metric that writes a 1 for all kind of log lines
2.) Define a custom event for alerting if the number drops below a threshold AND alert if metric shows missing data (meaning no log lines are written anymore).
Ok Thanks for the quick help
