Dynatrace API data to datalake
bill_scheuernst
DynaMight
DynaMight
How do I push data to Azure data lake or Event Hubs in order to speed up usage in PowerBI?
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
I guess you retrieve the data you are interested in via REST API from Dynatrace and store it as files. Then you upload data files to Azure Data Lake and query them.
Here's some what might help:
- https://docs.microsoft.com/en-us/answers/questions/226707/how-to-query-json-files-stored-in-azure-da...
- https://medium.com/@sarathsasidharan_92863/connect-azure-sql-data-warehouse-to-azure-data-lake-store...
Hope this helps you to start at least.
Senior Product Manager,
Dynatrace Managed expert
