Is there a way to get a list of all marked key requests & key user actions per tenant?
AmeyaD
Participant
Hi Team,
We would like to know if there is a way to get a list of all marked key requests & key user actions per tenant?
5 REPLIES 5
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
This REST API would help you:
Key Requests:
with Metrics v2 API: https://www.dynatrace.com/support/help/dynatrace-api/environment-api/metric-v2/
Key User actions:
https://www.dynatrace.com/support/help/dynatrace-api/configuration-api/rum/web-application-configura...
Senior Product Manager,
Dynatrace Managed expert
JhonKenneth
Participant
Hi @Radu are these links still updated to get all the marked key request? I can't figure out how it to get it.
Hi @JhonKenneth
Unfortunatly there is no API to get / update / delete key requests per service.
IMO its a must one and you can vote for RFE for that
HTH
Yos
apasoquen1
Helper
Is there a way to view this list via the UI?
Mahalo,
Aka
Maybe these posts will be helpful.
Best regards
