Alerting from Log monitoring - Need Example
bayu_irsan
Observer
Hello everyone!
I'm currently reviewing about Log Monitoring Classic that will be applied to one of our client's DT Managed environment.
From the Log Alerting documentation and demo I can use the metric I made from the log viewer in anomaly detection and make the threshold I desired. But I can't find the example of alert if the metric is reached the threshold.. So anyone here can help me to give the example?
Thank you for all the help and tips 🙂
4 REPLIES 4
Mizső
DynaMight Leader
DynaMight Leader
Hi @bayu_irsan
Here is an example problem about a log metric (it has 8 dimensions and this problem filtered for one dimension's anomaly):
I hope it helps.
Best regards,
Mizső
Hi, @Mizső , thank you for the help!
Can you tell me what made the alert for the error log? because I see in the graph the value is not changed during the problem time
Hi @bayu_irsan
Best regards,
Mizső
Oh there is a small thing above the threshold. I'm sorry for my dull eyes 😁
Thank you @Mizső , It's totally helpful for me!
