Can not select any management zone when create a problem alerting profile
hz974
Visitor
when i try to create a problem alerting profile, i can not select any zone in the dropdown list. always got error. but I can do it before. 2024-03-23 150754.jpg
8 REPLIES 8
Romanenkov_Al3x
DynaMight Champion
DynaMight Champion
Hello.
You can try to recreate management zone.
I would try to do it first.
Romanenkov Alex
DT_NGINX_FORCE_UNKNOWN_VERSION_INSTRUMENTATION=1
Malaik
DynaMight Champion
DynaMight Champion
Refresh your page, make sure that the MZ are correctly reported.
First time I see that guys encountered this situation.
Sharing Knowledge
hz974
Visitor
Mohamed_Hamdy
DynaMight Champion
DynaMight Champion
Hello @hz974 ,
I think this will appear if this management zone is removed at the same time you are selecting it in the alerting profile, try to refresh and check the available management zones again, and if the issue is still the same you can open a support ticket or use in-product assistance (Dynatrace chat)
Certified Dynatrace Professional | Certified Dynatrace Services Delivery - Observability & CloudOps | Dynatrace Partner - yourcompass.ca
hz974
Visitor
I can not select Any management zone in problem alerts profile , but I can select them in metrics event creation process. so i don't think the zone was removed. and also it is not possible to remove and re-create management zone. even I changed a computer and try, the issue is still there
PacoPorro
Dynatrace Champion
Dynatrace Champion
I would suggest to open a support ticket in this case.
hz974
Visitor
this is a UI bug in current version and confirmed by Dynatrace. it got fixed and I can select MZ now. thanks.
Thanks for feedback
