Default values for DT alert thresholds
rudolf_castelin
Visitor
Hi
Is there a DT doc that can list out all the default thresholds used by DT for alerting purposes?
For example, the DB alerting threshold for the response time of requests is set as follows:
  Absolute - 5ms
  Relative - 50%
However, I found these values after navigating to the DT Console > Settings > Anomaly detection > Database services > All requests section
Is there a page that lists all the defaults?
vsharma
Visitor
You can self service check in the /configuartion api and in swagger get the default values being set at your instance by  hitting endpoint /anomalyDetection/databaseServices
