How can I integrate Dynatrace with AWS SNS for problem notification?
Tim_Stewart
Guide
Re-asking question posted here: Solved: Dynatrace using AWS SNS for notification. - Dynatrace Community in case there are any updates. Is there anything out of the box or any recommended method for triggering events/problems from SNS topics?
jarinmusarrat
Dynatrace Guide
Dynatrace Guide
I found this document for AWS Amazon SNS notification https://www.dynatrace.com/support/help/how-to-use-dynatrace/infrastructure-monitoring/cloud-platform.... If this doesn't help I think you still need to create RFE
