IIs and Was Pool alerting
Malaik
DynaMight Champion
DynaMight Champion
Dear All,
What is the exact method to make an alert based on IIS/WAS pool ?
I have this need:
The custo;er want to be alerted when the
IIS pool exceed 800 connections.
WAS pool exceed 1800 connections.
What is the exact metric to take ?
What is the exact process to build ? (custom custom event for alerting) but i want to be sure for the building ...
Thanks for your help.
Sharing Knowledge
ChadTurner
DynaMight Legend
DynaMight Legend
you can set a bunch of custom alerts as it relates to Pool in the Custom events for alerting. Select the alert that most fits your needs, set the scope, and then define a threshold or allow it to be an automatic baselining.
-Chad
