Including starttime in the Dynatrace problem notification
moses_chacko
Organizer
Is there a placeholder that will I can add to show the starttime and end time of problem.
Moses
6 REPLIES 6
skrystosik
There is new placeholder that is containing html. Check this one, but there is no extra placeholder only for timings.
Regards, Sebastian
Link please
Go to go example service now integration on your tenant, there is list of placeholders
Sebasti
Regards, Sebastian
@sebastian k. did you mean {ProblemDetailsHTML}. If so it does not include the start or end times.
If not I have no idea, I've didn't test it. It was last chance to find it somewhere. Post an RFE for placeholders 🙂 For now you can only get problem ID from webhook and then access start time via API.
Regards, Sebastian
Community Team
Community Team
Here is the most recent list of available placeholders for problem notifications for email integration:
Available placeholders
{ImpactedEntities}: Details about the entities impacted by the problem in form of a json array.
{ImpactedEntity}: A short description of the problem and impacted entity (or multiple impacted entities).
{ImpactedEntityNames}: The entity impacted by the problem.
{NamesOfImpactedEntities}: The names of all entities that are impacted by the problem.
{PID}: Unique system identifier of the reported problem.
{ProblemDetailsHTML}: All problem event details including root cause as an HTML-formatted string.
{ProblemDetailsJSONv2}: Problem as json object following the structure from the Dynatrace Problems V2 API. The optional fields evidenceDetails and impactAnalysis are included, but recentComments is not.
{ProblemDetailsJSON}: Problem as json object following the structure from the Dynatrace Problems V1 API.
{ProblemDetailsMarkdown}: All problem event details including root cause as a Markdown-formatted string.
{ProblemDetailsText}: All problem event details including root cause as a text-formatted string.
{ProblemID}: Display number of the reported problem.
{ProblemImpact}: Impact level of the problem. Possible values are APPLICATION, SERVICE, or INFRASTRUCTURE.
{ProblemSeverity}: Severity level of the problem. Possible values are AVAILABILITY, ERROR, PERFORMANCE, RESOURCE_CONTENTION, or CUSTOM_ALERT.
{ProblemTitle}: Short description of the problem.
{ProblemURL}: URL of the problem within Dynatrace.
{State}: Problem state. Possible values are OPEN or RESOLVED.
{Tags}: Comma separated list of tags that are defined for all impacted entities. To refer to the value of a specific tag, specify the tag's key in square brackets: {Tags[key]}. If the tag does not have any assigned value, the placeholder will be replaced by an empty string. The placeholder will not be replaced if the tag key does not exist
There are no placeholders for the start and end times for the moment. You can create a Product Idea in the forum, and we'll make sure to mark one of our PMs to take a look at it 🙂
If you have any questions about the Community, you can contact me at maciej.neumann@dynatrace.com
