12 Jan 2024 09:56 AM
Hi, how can I send Dynatrace to BitBucket?
The aim is the to have a Bamboo build triggered when there is a low disk problem on Dynatrace. I have tried sending an alert to Bamboo but it was not working (using workflow). Now I want the alert to be sent to BitBucket Repo since it is linked to Bamboo.
12 Jan 2024 11:54 AM
Hi
Use the Webhook integration for this: https://www.dynatrace.com/integrations/webhooks/
Radek
15 Jan 2024 12:56 PM
Hi, I get the below error when using the Webhook integration. Please note that we are using Saas environment and this error does not appear when I try it on a managed Dynatrace environment.
