Avoid alerts limit for SLO: metric-selector-based configurations max 100
Slawa
Advisor
SLO created pseudo-metrics which not possible to use in Metric key configuration.
(Err: Stored metric expressions are only supported in metric-selector-based query mode.)
This leads to affective limit about 100 SLO or less:
Configuration limit of metric-selector-based configurations:
Static threshold: 4 out of 100
Auto adaptive threshold: 0 out of 100
Seasonal baseline: 1 out of 100
We want to have SLO for each key user action and different API.
In this case it is just impossible.
Based on standard best practices SLO should not be without the alert.
What is workaround?
Slawa
Advisor
I had a conversation with the support: limit can be increased to 500 by request for environment.
