13 Feb 2024 03:33 AM - last edited on 14 Feb 2024 07:36 AM by MaciejNeumann
we want to create dynamic tags using Aws imported tags to the underlying process & services.Is it possible?
All our engineering teams will send [AWS]serviceID=1234,whereas serviceID value will be changing for each host’s & application .we want to extract serviceID value and pass it as tags to the process & services.
thanks,
tarun
13 Feb 2024 07:05 AM
Yes it is possible:) Take a look at this documentation:
https://docs.dynatrace.com/docs/shortlink/tags-and-management-zones-aws
Radek
13 Feb 2024 12:55 PM
I am not aware of any way to dynamically propagate AWS tags via automatic tags.
You should create a rule for each "[AWS]serviceID"
I would say that using a host custom property would be a better approach in this case.
