Kubernetes - worker issue undetected
Hello support team!
We encountered an issue with Kubernetes, where all the pods failed on a specific worker.
No alert was raised, I believe because at no point the workloads had no running pods.
What do you think about this situation? How can an alert will be raised in this case?
We caught it by actively monitoring via our dashboards.
Thank ou!
Yosi_Neuman
Hi @YuvalKonstanti
Did you set on Alert on common Kubernetes/OpenShift issues
HTH
Yos
Hey @Yosi_Neuman , thanks for the answer.
Indeed everything is on,
The only thing I see that was off was: "Detect problematic node conditions" which I don't believe it's related because its explanation.
It seems that we failed under a specific condition that was not monitored correctly. I still wonder how it can be alerted via Dynatrace.
