Missing agent JAVA on container monitoring
sulaksono
Newcomer
We got a weird problem where our applications inside kubernetes containers aren't monitored (not showing in service. even multidimensional analysis don't show any of the requests)
Applications deployed in our weblogic are monitored without issue.
Deployment status of the said process is
Process isn't monitored
Process is ready to be monitored, waiting for injection status...
On diagnostic - the agent healthcheck.log show success but we got missing agents JAVA in the monitoring_state.json
What is the possible issue?
Ash
Julius_Loman
DynaMight Legend
DynaMight Legend
Difficult to tell without seeing the OneAgent diagnostic archive. There can be reasons such as secured containers, support for the particular container engine not being enabled, oneagent bug, etc... What kind of OneAgent deployment are you using?
