Monitoring Dynatrace pods with Dynatrace
arora138
Participant
We would like to monitor our Kubernetes pods running dynatrace (activegate, webhook, operator), with Dynatrace. We labeled the namespace but we're not seeing monitoring come up. We are on version v1.12.1 of the operator.
3 REPLIES 3
natanael_mendes
Champion
you see the pods running in your cluster? you opened the port 8443?
I don't think we opened the port, so I'll double check that!
islam_zidan
Champion
I believe you can see them through the Kubernetes cluster integration.
Dynatrace Certified Professional - Dynatrace Partner - Yourcompass.ca
