Oneagent not running on all nodes of AKS cluster
Aavesh
Frequent Guest
I had Dynatrace deployed to my Kubernetes cluster for quite some time now before I removed it to modify the config file. This was done as Dynatrace was not identifying it as a cluster. Before I removed it, oneagents were running on each of the 5 nodes of the cluster. After I redeployed DT, oneagents are running as it should only on 2 of the 5 nodes. Here are a few images explaining the issue.
List of pods in the dynatrace namespace
get podsget pods
Active pods (with consumption)
top podstop pods
Describing one of the pending oneagent pods:
describe poddescribe pod
There hasn't been any changes made to the cluster during the time redeployment was done, so there wouldn't have been any changes in the allocation/consumption of resources. Any input is appreciated. TIA
ChadTurner
DynaMight Legend
DynaMight Legend
Is your deployment using a containerized AG? What Dynatrace Operator version are you using?
-Chad
