Dashboard Menu Input Parameters - internal key and human key
HeadScratcher
Visitor
I have a a dashboard that runs some DQL based on an input parameter called $AppChoice.  This functions fine but is really anti-user friendly as the AppChoice is a kind of private key in our organisation i.e. just a reference number.   So you have to look it up or remember it (yuk, I know)
What I would like is to present the dashboard user with a human friendly string such as "Horizon App" and then convert that string over to the internal reference that is required for the DQL to work correctly.
What is the best approach for this.    Appreciate any suggestions...
NOTE: I am coming from a Splunk environment where we would probably use a csv or DB lookup as a solution.
0 REPLIES 0
