Auto adaptive/Seasonal baseline metric event added to dashboard
Vasil_Penev
Visitor
Hello Guys,
Is there a way to pin output from either seasonal baseline or auto-adaptive threshold to a dashboard because I'd like to add such tile as a way to have an insight whether an alert might pop up?
Vasil
3 REPLIES 3
Mohamed_Hamdy
DynaMight Champion
DynaMight Champion
Hi @Vasil_Penev,
I think this is not available, however, you can create a graph tile on the dashboard and select the last 7 days for instance then apply a baseline to the Graph tile
also, you can check Prediction-based anomaly detection that might help using the parameter predict=true to Dynatrace Metrics API v1 request, for more details check the following URL
https://www.dynatrace.com/support/help/shortlink/anomaly-detection-prediction#application-load-predi...
note that the prediction will be calculated for the next 30mins only as I remember.
Certified Dynatrace Professional | Certified Dynatrace Services Delivery - Observability & CloudOps | Dynatrace Partner - yourcompass.ca
This is true, but you can't currently display the baseline on a dashboard - it's only visible in Data Explorer.
islam_zidan
Champion
Hi @Vasil_Penev
There is a product idea for that which is currently under review, you can share your use case there for better reach.
https://community.dynatrace.com/t5/Product-ideas/Option-to-apply-Seasonal-baseline-intelligence-to-A...
BR,
Islam
Dynatrace Certified Professional - Dynatrace Partner - Yourcompass.ca
