Availbility dashboard for missing processes
tobydavies
Frequent Guest
     I want to create a dashboard which shows which processes are running, and which are not for a known set of processes. Normally, I'd create a honeycomb and put the cpus of the processes in there, with >0 being green and red being everything else.
However, this fails since if the process is not around for a few days, the hexagon disappears leaving no indication to the support team that it should have been there.
What is the best way to make the dashboard so that the information is preserved that some process should be up but is not?
dannemca
What if you increase the timeframe selector to 7 days or more?
I believe your team will have plenty of time to work on the issue before it got cleaned from Dashboard.
