Data explorer not showing small values
elenaperez
Dynatrace Participant
In a data explorer graph with the process CPU with some filters applied and split by process group instance and host: The 13th of September the CPU dropped a lot (expected behavior). However, even though some processes are still consuming small amounts of CPU, nothing appears in the graph.
This is one example:
And this is what the data explorer graph shows:
When the CPU is around 0.15% it doesn't show anything in the graph. Why is this? Is there a way to see this information even though the percentage is small?
victor_balbuena
Dynatrace Mentor
Dynatrace Mentor
Hey @elenaperez ,
Seems like you are looking at two different metrics here. The one above is builtin:tech.generic.cpu.usage meanwhile the one below is builtin:process.cpu. If you were to chart in your dashboard the one above, the "small" numbers of that metric would show up in the dashboard as well. The other metric (builtin:process.cpu) has actually stopped being populated, at around the same time that there is the drop of CPU usage in your other metric.
So the problem is no longer charting small numbers, because of course the Data Explorer can do that, but why did the second metric (builtin:process.cpu) stop being populated so harshly for so many processes. For this, I don't have an answer, but hopefully someone else does, reads my comments and can add their more professional insights into why it could disappear.
Hopefully this helps.
