Filtering Dashboard data using Generic tag key
Sahil1999
Observer
I am trying to Filter Dashboard data using Generic tag key, I have a K8 cluster with multiple application on diff namespaces, I have introduced tags for the same.
While filtering dashboard data using tags I am facing issues, if the tile is made using advance query in data explorer, the data is not reflecting as expected, can anyone kindly help here :).
Thanks in advance.
3 REPLIES 3
radek_jasinski
Hi @Sahil1999
can you present this tile and how you made the configuration?
Radek
Have a nice day!
Hi @radek_jasinski ,
I am using this query in data explorer : (builtin:kubernetes.node.requests_cpu:last:splitBy("dt.entity.kubernetes_cluster"):sum / builtin:kubernetes.node.cpu_allocatable:last:splitBy("dt.entity.kubernetes_cluster"):sum * 100):sort(value(sum,descending))
When adding this tile to dashboard, I am making the following dashboard config for tag.
Then applying the filter
I have made a auto tagging rule for K8 tags.
Kindly let me know any suggestions you have 🙂
zietho
Dynatrace Champion
Dynatrace Champion
Hey, thx for reaching out. Can you please elaborate a bit more about what doesn't work?
What works when you start in simple mode?
