Ingest metric (v2) using dt.entity
tarjei_utnes1
Visitor
Hi!
Is it possible to ingest a metric using v2 to an entity using the entity selector? Or is it only possible using explicit entity ids?
Julius_Loman
DynaMight Legend
DynaMight Legend
Only entity IDs. You can lookup those by calling the Monitored Entities API
Taylor-Sanchez
Dynatrace Advisor
Dynatrace Advisor
Adding to what Julius said here, that is correct. In addition, if you wanted to query for the monitored entities - this would be done through the API here:
https://docs.dynatrace.com/docs/dynatrace-api/environment-api/entity-v2/get-entities-list
Dynatrace ACE Services Consultant
