Problems logging in
Lwl
Helper
Three people access Dynatrace Managed, one of whom has access and the other two cannot, under the same network look forward to hearing from you
10 REPLIES 10
Mohamed_Hamdy
DynaMight Champion
DynaMight Champion
Hello @Lwl ,
are you talking about network access or user access?
if you are talking about network access are the users using IPs to access Dynatrace UI or using a domain, if you are using a domain and there is a certificate is it centralized or not, if not then I think they need to add the domain in the hosts' file, but I think in that case they are able to access the UI using the IP normally.
we would like to know more details to be able to support
Certified Dynatrace Professional | Certified Dynatrace Services Delivery - Observability & CloudOps | Dynatrace Partner - yourcompass.ca
Local user ip address access
radek_jasinski
Are you using the built-in user database in Dynatrace or do you have integration via LDAP or SSO? Have you tried deleting the faulty account and sending the invitation to the user again? Don't the users have any blocking plugins in their browser? (I have also encountered this)
Radek
Have a nice day!
Thank you very much for your reply, using the built-in default database, the situation is that sometimes it is not possible to open the login page, but sometimes it is possible to log in
It looks to me like a network problem at your organisation.
Have you verified the network passes or maybe something is scanning the network every so often?
Have a nice day!
Very good idea, I also feel that it may be the network problem, but do not know how to test
You can find some tips here: https://www.practicallynetworked.com/network-stability-test/
Generally if the problem was on the DT side then the user would not be able to log in at all. If network verification doesn't help then you will need to see what you have in the DT logs
/var/opt/dynatrace-managed/log/server/
Have a nice day!
Thank you very much for your help. Thank you very much! Although it can not directly change the problem, but gave me a certain idea
No problem:) If you have any additional questions let me know:)
Have a nice day!
Well, thank you in advance
