Effectively to monitor and troubleshoot your applications
natanael_mendes
Champion
useful tip for using Dynatrace effectively to monitor and troubleshoot your applications:
**Tip: Set Up Custom Alerts for Critical Business Transactions**
While Dynatrace provides automatic anomaly detection and alerting for various metrics, it's essential to create custom alerts for your critical business transactions. These are the transactions that directly impact your business's success, such as user registration, checkout processes, or specific API calls.
Here's how to set up custom alerts for critical business transactions:
1. **Identify Critical Transactions:** Determine which transactions are vital for your business. These might be revenue-generating transactions, user engagement actions, or any other key performance indicators.
2. **Define Custom Thresholds:** Custom thresholds allow you to set specific performance criteria for each critical transaction. For example, you might set a threshold for response time, error rate, or throughput.
3. **Configure Alerting:** In the Dynatrace dashboard, go to the "Alerting" section and create custom alerts for your critical transactions. Set up alerts based on your defined thresholds. You can configure notifications via email, Slack, or other channels.
4. **Include Contextual Information:** When creating alerts, consider adding contextual information, such as the affected application, service, or user impact. This helps your team understand the urgency and context of the alert.
5. **Test and Refine:** After setting up alerts, perform testing to ensure they trigger when expected. Tweak the thresholds if necessary to strike a balance between avoiding false alarms and catching critical issues.
6. **Collaborate and Automate:** Ensure that relevant team members are notified when critical alerts are triggered. Consider integrating alert notifications with your incident management and collaboration tools for seamless incident response.
By setting up custom alerts for your critical business transactions, you can proactively identify and address performance issues before they impact your users and business operations. This helps you maintain a high level of application reliability and user satisfaction.
radek_jasinski
Thank you!
Have a nice day!
danielD
Dynatrace Helper
Dynatrace Helper
These are some good tips, cheers.
