Metric Events limits
AntonioSousa
When dealing with metric events, you might have to be careful with metric expressions. If not, you might get into situations like this one:
The Settings page has some links to the documentation,
but also a link to Data Explorer, which uses the following metric expression:
  • dsfm:server.anomaly_detection.metric_events.monitored_dimensions:splitBy("dt.config.name"):last:sort(value(auto,descending)):limit(50)
When looking for a good usage of metric expressions in the context of metric events, you should monitor this well, so you don't get affected by throttling.
Antonio Sousa
ChadTurner
DynaMight Legend
DynaMight Legend
Great Pro tip @AntonioSousa Its also important to understand the gains/losses and limitations between each type of entity selector as Alerting on missing data is only supported for metric-selector-based query definitions.
-Chad
