Alerting for RabbitMQ for Consumer count and Message Rates
Munzir
Contributor
We want to set an alerting profile for RabbitMQ if the Consumer count is dropping, eg from 8 it goes to 7 or 6 there has to be an alert.
Along with it if the Message rates is crossing 1000 then a warning alert should be raised and if it goes above 1500 then critical aler tshould be raised
radek_jasinski
To do this, a Metric Event must be created for the Consumers metric.
You can find all metrics for RabbitMQ here:
https://www.dynatrace.com/support/help/shortlink/rabbitmq-monitoring#rabbitmq-cluster-monitoring-met...
How to create a metric event can be found here:
https://www.dynatrace.com/support/help/platform/davis-ai/anomaly-detection/metric-events
Please note that you will need to create an Alerting Profile if you want to send information about this event by email, for example.
Radek
Have a nice day!
