MSSQL Extension using NTLM and the credential Vault
AmitChiba
Helper
I am currently testing the MSSQL Extension that is available. I do see that the extension supports NTLM which is a requirement of ours. Does the extension support stored credentials in the vault for NTLM or is it only supported for Basic Authentication? If it does not currently support it, are there plans to add support?
Kind Regards,
Amit
vagiz_duseev
Dynatrace Helper
Dynatrace Helper
Credentials vault is not supported with NTLM or Kerberos authentication schemes at the moment.
Perhaphs, @dglugla knows if there are any plans to enable that?
