02 Sep 2023 01:55 AM - last edited on 04 Sep 2023 07:43 AM by MaciejNeumann
Hey guys,
It's possible to get metrics from monitored database like Oracle, Postgre using Grail?
Today we are using third party extension to run queries and get data but for some reason it is not fetching it correctly.
Thanks!!
08 Sep 2023 11:13 AM
If you have extensions that monitor your databases you can fetch them by using Metric API. With Grail you can currently fetch only built-in metrics.
Best Regards,
Mateusz
12 Sep 2023 09:55 AM
Hi Mateusz,
is there any plan to send extension metrics to Grail ? near future ?
Thanks for your answer
