SSL Certificate Monitor - " Add HostName information on Problem Notification"
Ranjeet_Tiwari
Observer
I am looking for small modification in "SSL Certificate Monitor" Extension's   "Certificate Status" Metric.
as of now Metric does not have Problem attribute where i can find out HOSTNAME where certificate in impacted.
it only have generic problem attribute.
can we have Problem variable included  "HOSTNAME" when source in "LOCAL" ?
and also if possible can we get information regarding "CODESigning" certificate also?
Thank you .
Miguel_RinconG
Dynatrace Advisor
Dynatrace Advisor
Hi Ranjeet,
You can use the host split  of the metrics certificate.monitor.status:
