Connectivity problem and process restart
DXCAnilKumar
Visitor
My Websphere Process is getting frequent connectivity issue and it's going process restart. Could you please guide me to troubleshoot this. Here I am attaching screenshot from Dynatrace monitoring.
PierreGutierrez
Dynatrace Mentor
Dynatrace Mentor
Hi @DXCAnilKumar
There are many reasons why your "Websphere" process may restart unexpectedly, for example: OS failure, memory problems, critical errors in your applications, hardware problems, etc.
The image you share with us does not have enough information to understand the context of the problem.
However, I tell you that it is rare for a connectivity problem to lead to a restart of the process.
I hope it's helpful 💪
