Davis is monitoring how many dependencies per problem?
Dave_Anderson
Inactive
Warning - this is a bit of a competition 🙂
  • At Perform Las Vegas 2019, our CTO and Founder Bernd Greifeneder said the number of causations analyzed by Davis per minute was 55b. Five months later at Perform Summit Barcelona, he revealed this number is now 2500b.
  • And, our SVP of Product Management, Steve Tack shared that one customer had 235 billion dependencies analyzed per problem.
Today, as part of an interview with a customer for an upcoming webinar, we noticed they had a problem detection with a number of dependencies analyzed that had to be seen to be believed.
Which had me thinking, within our customer community, who has the largest number of dependencies analyzed per problem? Billions? Trillions? Is there a number bigger than trillions?
So now I’m on the hunt.
Please share with me a screenshot of your Davis dependency count, and I will publish the findings in a follow-up blog. And no, asking your marketing team for a photoshopped version doesn’t count because we can verify every entry if we really needed to.
This is one of mine. Doubt I will win.
And don’t worry, all information shared will be kept confidential, and no company names will be revealed without approval.
We will randomly select some submissions to receive custom Davis stickers and swag.
Get in touch with us at DynatraceSocial@Dynatrace.com and use the subject line Getting Smarter with Davis or you can post below? If you feel like it you can also share this post on linked In. https://www.linkedin.com/feed/update/urn:li:activity:6557664472385802240/
9 REPLIES 9
ctturner
Inactive
Over 32 Billion!!
skrystosik
104 bilions 🙂
Regards, Sebastian
I've made little more digging and found this one 🙂
Regards, Sebastian
pahofmann
Just one from today, I'm sure there are bigger ones with a little digging:
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
barryla
Helper
Over 10 trillion....
ecstarkey
Visitor
Not going to win but I am up for the swag.
Domenico_Bressi
Advisor
56 Billion 🙂 not the winner but fine to be part of the game 🙂
larry_roberts
DynaMight Champion
DynaMight Champion
Ok this just made me think... How can you find your biggest dependency count in an environment?
It seems that the logic behind this count of depedencies analyzed by Davis has since then changed, right? People are posting here numbers in the range of billions, whereas when looking at the demo environment or other customer  environments, the count is more like tens of thousands of dependencies. Does anyone have any further info on this?
Btw based on the old screenshots, it used to say just "dependencies", and now it says "dependencies
across monitored entities". Why the change?
