Management zone rule using customPgMetadata
Olav_Wollrab
Frequent Guest
I added metadata to a process group as recommended in
https://docs.dynatrace.com/docs/manage/tags-and-metadata/basic-concepts/best-practices-and-recommend...
Now I want to make use of it in a management zone rule.
I fail to do so. I tried: type(process_group_instance),customPgMetadata("Environment=Level_01")
Can someone help me with it?
P.S.: my current workaround: I use an automatically applied tag rule to lift the information into a tag which I can use with the management zone rule.
Regards, Olav
4 REPLIES 4
ChadTurner
DynaMight Legend
DynaMight Legend
I was able to complete this ask. Granted this is set at the host level but can be applied to PG instances via PGs with the following:
-Chad
Romanenkov_Al3x
DynaMight Champion
DynaMight Champion
My example rule for autotaging:
type(process_group_instance),processType("NGINX"),customPgMetadata("[ENVIRONMENT]DOG:CORGI")
Result:
Manifest:
yaml:
        - name: DT_CUSTOM_PROP
          value: "DOG=CORGI"
This is response from API (ENV v2) /entities/{entityId}
I have to use this API to create right entityselector. It is really helpful. You need to define only EntityID - from browser -PROCESS_GROUP_INSTANCE-XXXXXXXXX and you will get all properties in JSON.
Hope this helps and good luck.
Alex Romanenkov
DT_NGINX_FORCE_UNKNOWN_VERSION_INSTRUMENTATION=1
Mohamed_Hamdy
DynaMight Champion
DynaMight Champion
Hi @Olav_Wollrab ,
you can also try the following
type(process_group_instance),customPgMetadata([ENVIRONMENT]Level_01)
type(process_group_instance),customPgMetadata([ENVIRONMENT]Level_01:QA)
Certified Dynatrace Professional | Certified Dynatrace Services Delivery - Observability & CloudOps | Dynatrace Partner - yourcompass.ca
Olav_Wollrab
Frequent Guest
Gentlemen, thanks to all of you for your valuable input. 🙂
Regards, Olav
