Problem notification: applied Custom Tags with hook don't work
Stef_Stouf95
Participant
with the syntax {Tags[key]}, as mention in the doc,
i have this syntax in the Tag [company][team]os
example tag applied : [microsoft][hr]os:windows
i try to put in a Problem notification : {Tags[[microsoft][hr]os]}
without success, the value isn't returned, just the "Tags[[microsoft][hr]os]"
regards
theharithsa
Dynatrace Champion
Dynatrace Champion
Hi @Stef_Stouf95
Looks like you are using the syntax in a wrong way. If you have a tag with key as OS and Value as Windows, you need to pass the tag as {Tags[OS]}. Also if you want to add one more tag you need to use another parameter with comma seperated. For example, {Tags[OS]}, {Tags[Key 2]} etc.
Love more, hate less; Technology for all, together we grow.
Stef_Stouf95
Participant
I use the tag system, whatever the format you can add it like this.
that's can be [microsoft][hr]software:talend
Agreed with you, the basic format works well as {Tags[os]} or {Tags[software]}
What's the syntax to retrieve the value on Problem notification, with a key tag containing a hook ?
Regards
