Create a program to enable/disable any DT Synthetic monitor
vinit_dhamani
Newcomer
Hi All,
We are trying to create a script in python or JavaScript so it can be hosted on backend and run by us. This will enable any user in organization to enable or disable the specific monitor.
Is there any script available already to accomplish this?
I checked in the community and found solution for bulk enable/disable which is of no use for us.
Note: I know Synthetic Monitors API through which need to create a token and pull the monitor ids using Get all monitors
But how to achieve this via python or any other language? I am looking for that solution.
Thanks in advance.
Yosi_Neuman
Hi @vinit_dhamani
Check Bulk-Enable-Disable-Monitors
HTH
Yos
