Dynatrace Synthetic Monitoring credentials using PAM api
jordan_rose
Helper
Is there any way for Synthetic Monitoring transactions to call the CA PAM api to get a user account/credentials?
Our security team is pushing for a "check in/check out" process for certain service accounts. If we could call the PAM api to get the account and credentials this would satisfy that need.
4 REPLIES 4
Philipp_Kastner
Dynatrace Pro
Dynatrace Pro
Hi @jordan_rose,
are you using browser monitors? If yes, you can use a JavaScript event to execute simple API calls.
Similar to the example shown in the help
Hope this helps,
Philipp
jordan_rose
Helper
Hi Philipp, thanks for the reply and this is very helpful. Once I retrieve a user name how can I set it to a variable and input that into a form field. I looked through the doc and didn't see this and I haven't had any need to edit the scripts of the recorded click path yet so forgive me if I'm missing it.
Any help on this much appreciated!
You have two options.
1. You can store the user name via api.setValue and use it in a subsequent keystroke events via placeholders for example {username}.
2. You set the value of the input directly via JavaScript.
Example
api.startAsyncSyntheticEvent();
fetch('https://randomuser.me/api/').then((resp) => resp.json()).then(function(data) {
    // Option 1 - Store username via api.setValue to use in subsequent events
    api.setValue("username", data.results[0].name.first);
    // Option 2 - Set input value directly via JavaScript
    document.getElementById('username').value = data.results[0].name.first;
    api.finish();
}).catch(function(error) {
    api.fail('Fetch request to randomuser.me failed');
Using the placeholder in a subsequent keystroke event
Kind regards,
Philipp
Phillip, this is awesome, Thank you so much for replying with this info. I will do some testing to try to get this working....
