Timestamp for each event in a synthetic browser monitor?
AntonioSousa
Is it possible to know when a synthetic event started happening? We do have the start and end time for the whole "transaction", but it seems to not have the timing for when each event happened. Before submitting a Product Idea, does someone have an idea if it's possible to get this information?
Antonio Sousa
I am unsure if this is what you're looking for and if you want to refer to the timestamp of each event in terms of a metric, but if you select Synthetic sessions in the top of a browser monitor, this will show all recorded synthetic sessions like this.
If you select one, you get the timing of each synthetic event.
Is this what you are looking for?
@marina_pollehn,
Yes, thanks! Was concentrating on the screen that has the events / screenshots, and totally forgot about the session data!
Going to put in a Product Idea so that for each measurement there can be a link to the session.
Edited: Product Idea here: https://community.dynatrace.com/t5/Product-ideas/Link-from-a-Synthetic-measurement-to-the-correspond...
Antonio Sousa
