22 Dec 2022 10:33 AM - last edited on 22 Dec 2022 11:24 AM by MaciejNeumann
Hi community (my first post !) !
I tried to register a Synthetic monitoring on a WebAp using Kerberos Auth only.
Some considerations :
> From a Windows opened user session, I'm available to access this WebAp with my Kerberos token.
> There is no prompt for login/password (no other possibility that Kerberos, no Auth alternatives)
It looks like Synthetic Monitor can"t run that kind of Authentication.
Manually, I succeeded to log in, setting manually in cookie a "gssapi_session / MagBearerToken=xxxx" in the advanced setup of the Monitor Settings. (Token retrieved from browser debug to accessing WebAp)
But this token is only valid for some hours, so that can't be the solution to run for monitoring.
Vault doesn't seem to be the only solution, as (I think) it doesn't/can't play the Kerberos Auth.
So the idea may be to run something like "kinit" via the Vault to run the Kerveros Auth and then be able to use it in the Synthetic Monitoring.
If you have any experience, confirmaton/invalidation, suggestion ...
Thanks for your help !
CMEL
(Depending on the replies, it may be a post to recreate in "Product Ideas" ?)
(1st post ! Hope that's a good one ^_^)
22 Dec 2022 11:12 AM
I assume you are doing the synthetic tests from a private location, right? In the case of Synthetic ActiveGate for Windows this is achievable by running the synthetic engine as the user who has access to the Web Application.
22 Dec 2022 12:50 PM
Oh, yes I'm running in private location, but I have tried for now only under Linux AG ! (running Dynatrace Managed on-prem, forgot to say it)
I'm gonna try on Windows AG and set a service account user to try this.
> I'll let you know the result (next year now) 🙂
(But it could be also a great thing to be able to run this kind of test under Linux !)
Thx !
22 Dec 2022 01:02 PM
Well - I'm not sure about getting that working on Linux - but I would guess the same applies - and you have to "log in" the user which is running those synthetic tests.
@HannahM is there any recommended solution?
05 Jan 2023 04:17 PM - edited 05 Jan 2023 04:20 PM
Kerberos definitely prefers windows, so I would go with Julius's suggestion of trying that and logging the Dynatrace Synthetic service on as a domain user - you will need to disable auto-updates if you do that though, as the Service defaults back to the Local Service user on update. So you will need to add the extra step of resetting it to your upgrade run book.
For Linux machines, we will likely need to add the following line/ lines (depending on what the setup) to the user.properties file in the \dynatrace\synthetic\config directory.
com.ruxit.vuc.poolConfig.playerConfig.additionalStartupParams=--auth-server-whitelist="_" or com.ruxit.vuc.poolConfig.playerConfig.additionalStartupParams=--auth-server-whitelist="customerdomain" com.ruxit.vuc.poolConfig.playerConfig.additionalStartupParams=--auth-negotiate-delegate-whitelist="customerdomain"
06 Jan 2023 10:03 AM
Thanks for the reply.
The problem is that we have hundreds of applications to check. And we can't have common user credentials to test them. So that means that we must run a dedicated ActiveGate for each credential we have to access via Kerberos ...
So, I think that we can't run our checks like this.
Do you think I can post as an "idea" to have Kerberos credentials managed for Synthetic ? I must not be alone having those security constraints.
Having in the monitoring script something like a checkbox to use a credential Vault with a Kerberos init (providing domain informations) would be perfect !
CMEL.
06 Jan 2023 11:15 AM
For many instances just adding the credentials using HTTP Authentication is sufficient but it really depends on the set up. If you create a support ticket we can try to see if we can get it working and then you can decide if a Product Idea is required.
17 Oct 2023 09:57 AM - edited 17 Oct 2023 09:58 AM
Update to the previous changes that were used for setting this up on Linux.
To add the settings to your Linux ActiveGate you need to add either
com.ruxit.vuc.poolConfig.playerConfig.additionalStartupParams=--auth-server-allowlist="_"
or
com.ruxit.vuc.poolConfig.playerConfig.additionalStartupParams=--auth-server-allowlist="customerdomain"
com.ruxit.vuc.poolConfig.playerConfig.additionalStartupParams=--auth-negotiate-delegate-allowlist="customerdomain"
to the /var/lib/dynatrace/synthetic/config/user.properties file directory and then restart the vuc.service.
You may then need to write the credentials as "USERNAME@DOMAIN" (<== All uppercase, DOMAIN in FQDN).
14 Feb 2023 11:08 AM
We have a similar issue here at Swiss Post. We try to monitor Webapplications which use SSO with Kerberos (Negotiate). Our ActiveGates are also running on Linux. We have now setup a Windows server for an additianal ActiveGate. However, we would prefer Linux.
The interesting thing is, when executing a `kinit`and then starting the Chromium browser (via X11 forwarding) on the Linux host on which the AG is installed, it works. So we are not really sure, how the ActiveGate performs the Kerberos authentication. As we configure the credentials as HTTP extension, i assume that a login window from the browser is expected. Without the `kinit` the Chromium browser does not display such a login window. In our case we are redirected to a 2FA login page.
We have now opened a support ticket to analyse this in detail.
Kind regards,
Patrick
