26 Apr 2022 12:40 PM
Hi there.
I need my synthetic monitor to insert a cookie with a timestamp in it, in the format 2022-04-26T11:33:29.693Z.
In the Advanced section under Set Cookies, there is a comment "Enclose placeholder values in brackets, for example {email}", so I assume I need to do this using placeholders.
So the question is - is there a timestamp placeholder already available that I can use, or do I need to create a new one?
If there is one already available, is there a list somewhere. If not, how do I create it?
Many thanks,
Ian
26 Apr 2022 01:07 PM
Hi Ian,
You will have to create a placeholder in the script section using the api.setValue() method.
Ref.:
HTTP Monitor - Pre and post scripting: https://www.dynatrace.com/support/help/shortlink/http-monitor-pre-post-script#variables
Best,
26 Apr 2022 08:58 PM
Many thanks Andre. I'll give it a go and let you know how I get on!
Ian
19 Dec 2022 11:38 AM
Hi @ifordyce-s95, were you able to receive some satisfying results eventually? Thanks in advance for any feedback, it would be fantastic to know!
